Hide the Detail view head and line
basheer.algohi
Message 1 of 10
basheer.algohi
How can I hide the Detail view head and line as shown in the image.
This comes to indicate other elevations generated from an assembly
Replies (9)
Message 2 of 10
WEC17
Create a filter name unreferenced section. check the attach image for a better idea.
Once you have it click Visibility
Message 3 of 10
Do you know about Hide in View? Select the Marker, right click and press Hide in View. From there you have 3 choices: By Element, By Category or By Filter.
I notice the View Scale is 1:20.  Ours are typically Hidden at that scale via the "Hide in Views Course Than" Property of the Marker.  Check it out.
Message 4 of 10
VG > Annotation categories tab > turn off Sections
Message 5 of 10
basheer.algohi
Thanks  for the answer
I have more than 300 assemblies and doing it one by one is hard.
I am aware of VG stuff but I was hoping to do it on the family level so that it applies to all assemblies.
Message 6 of 10
basheer.algohi
Yes but that will not work as I have over 300 of such views.
A global setting will be desired
thanks
Message 7 of 10
You can create a View template with Sections turned off and assign it to all Assembly plan views.
Message 8 of 10
basheer.algohi
I have to activate the filter for each view.
This is not going to work as I have too many such views.
thanks
Message 9 of 10
RDAOU
@basheer.algohi
Would you settle for a dynamo script that does it for you? and if yes do you by any chance have a specific naming convention for the generated views?
Message 10 of 10
basheer.algohi
