hide rows in wall schedule
BIM_Dreamer
Message 1 of 24
BIM_Dreamer
how to hide rows in wall schedule,  any suggestion. thanks
Replies (23)
Message 2 of 24
syman2000
I would add COMMENT parameter and then add the value EXCLUDE. In the filter you would set COMMENT Does not equal EXCLUDE.
Message 3 of 24
BIM_Dreamer
can you please show me how to do it. thanks
Message 4 of 24
What's the criteria to meet to have the row hidden.  Filter it out by "Does not Equal".
Message 5 of 24
syman2000
Sure.
In the filter, you add in Comments does not equal EXCLUDE
The wall will hide itself.
Message 6 of 24
BIM_Dreamer
that worked. thank you
Message 7 of 24
What worked?
Message 8 of 24
_Vijay
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
Message 9 of 24
BIM_Dreamer
how i'm going to hide those walls that i cannot type or keyin EXCLUDE in the wall schedule. thank you
Message 10 of 24
syman2000
Are those wall linked in or in a group? Normally Revit linked you won't be able to enter in information until you edit the link model and type in those value.
Message 11 of 24
What are being excluded? What criteria? There may be another way other than type in Comments for every wall.
Message 12 of 24
BIM_Dreamer
they are in model in-place stacked wall and don't  want them to see in wall schedule? cannot type exclude in comments in schedule, thanks
Message 13 of 24
BIM_Dreamer
do you have any idea? i did that in comments/exclude because they are model in-place as walls and don't want them to see in wall schedule that is the reason i want them to hide. thank you
Message 14 of 24
Do it in reverse. Select all the walls you can enter Comments and enter Included. Then filter the schedule using Comments = Included.
Message 15 of 24
BIM_Dreamer
thank you for your reply but there are 100's of type wall in schedule it will take me time? i tried and i did i add description fields and type EXCLUDE and set the filter to description = does no equal = EXCLUDE and i think it worked able to hide them, but not sure if this the correct approach. thanks you
Message 16 of 24
Why don't you exclude all the model in-place walls and forget comments.
Message 17 of 24
BIM_Dreamer
how? please show me how to do it. thank you
Message 18 of 24
syman2000
Stackwall is an abnormality since it is consist of host wall. You are pretty much stuck and can't use the comments. However if you tab it, you can select the sub-element of the wall
Enable the structure and you can define structural to another category not used by your structural consultant
In your filter, you add Structural Usage and set to does not equal to Structural combined
My suggestion in the future is to use wall footing as your alternative
Message 19 of 24
BIM_Dreamer
 i will try and let you know . thank you
Message 20 of 24
If you don't want to type anything to Comments, then create different basic wall types to be used in the stacked wall types. Then filter using type names.
