Hide elevation tags on unreferenced levels
cbt990
Message 1 of 8
cbt990
I am placing interior elevations in a corridor at each floor, I started with the Ground Level.
I move up to L2 to place my elevation but the one below is already visible.
I think it is going to be confusing to manage 5x coincident tags that are hidden from view. Is there a way to set these up so that they only appear on the plan from which they were created?
Revit is amazing
Replies (7)
Message 2 of 8
Why are you placing another one then?  Crop boundaries of the two if you must do separately.
Message 3 of 8
cbt990
never mind. my instructions are to hide all interior elevation markers from the plans, which makes it easier to just hide all at scale coarser than x.
Revit is amazing
Message 4 of 8
I'm not following your thinking. Certainly, there will be Plan Views where those markers will need be visible.  No?
Message 5 of 8
cbt990
i was instructed to add a key plan per floor. So I guess I just have to hide them individually since I will have to enable visibility on some plan.
Revit is amazing
Message 6 of 8
Lachlan-JWP
The reason why the elevation markers from the floor below show up is because the view extents of the elevation intersect the view depth of the floor plan. You can either adjust each of these so that they do not intersect or you can hide the incorrect views manually where required.
Message 7 of 8
cbt990
Why would they all be visible in my site plan?
Revit is amazing
Message 8 of 8
Because they are all within the View Range.
...what scale is your Site Plan?  Reason I ask is because you mentioned you know about Hide at "View Scales Coarser than".  Generally, Site Plans are well above the typical scale of Elevation Views.
