Hide a rebellious revision entry in a schedule
andrew8QEC8
andrew8QEC8
We have a revision schedule as part of our sheet family. We need to hide all the revisions in the schedule. They all have been given the same settings as can be seen in the picture below, and the revision clouds have been turned off. Yet Revision Number 2 has a rebellious streak and won't turn off no matter what is done. Why can I not filter this one and only this one revision tag out of the view?
syman2000
Have you try edit revision on sheet and see if you can check off the revision 2?
If that didn't work, then you may want to turn on all revision and you go into the views and see if there is a hidden revision cloud.
Change to Show Cloud and Tags, then Reveal Hidden Elements, select Cloud and Hide By Element.
