Disclaimer:
This isn't critical, it's just out of curiosity. If anyone else has noticed this and knows offhand if it is a Revit limitation or just a setting I'm missing, that's cool. This is in LT, so it could just be an LT thing.
Noticing a couple weird things with material cutouts:
1) The first one is this door. The hinges are actually on the other side of the door but we can see them through the door. Where the hinges overlap the door, their edges glow. Where they overlap any other material, they are solid.
2) The other is this bay window with leaded glass. Where the material overlaps another window on the other side, the leading becomes translucent.
Maybe if I render it, everything will display just fine?
Thanks in advance.
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
I notice the cutout may not show correctly in the realistic view. This is an example scene where the realistic view shows no cutout appearance and the cutout shows up when I use enscape to render the scene.
