01:56 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
hi there,
I am modelling a site, and imported the current site survey from old DWG file. Unfortunately there is no Z points on the DWG and therefore when I try to create Toposurface from import I get Elevation Points but there are all set to Zero.- basically it is flat, no elevation points on original survey.
Is there any easy way or some shortcuts to help me create Toposurface from flat contour line drawing? Do I need to manually place the points on the lines? There are many contour lines and good variation the topography of the area so looking for any shortcuts.
Thanks in advance
Helen
