help with software
help with software
help with software
hi mike here newbie  i downloaded the revit trial and didn't get any families or utilities
so i can't place doors or windows
can anybody help thanks mike
You should go to Control Panel > Programs > Uninstall a Program.
Look for Autodesk Revit Content Libraires 2018.
Select Uninstall/Change
Add/Remove Features
Select the Region Content you wish do download.
Click on Next.
I Hope it help.
Tony_Michniewicz
If the method suggested above does not resolve the issue, you can also download the necessary Revit content files from this page: https://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/autodesk-revi...
Tony Michniewicz
Revit Software QA Analyst
i did that tried to load families window opened files were empty
it should be in the program that i downloaded y wouldn't be
sounds to hard may have to look for other all in one programs
thanks mikec
