Help with ramps
Help with ramps
cbt990
Help with ramps
cbt990
After my adventure moving the whole building today, this should be an easier one. every time I try to adjust the ramp landing to how the red lines are shown, it fails to rebuild. is it possible to do it like this?
Revit is amazing
I'd put a floor there and shape-edit it (e.g. Modify Sub-Elements).
cbt990
How did you achieve that? 😕
Revit is amazing
The key is to draw the ramp in a way that the runs meet exactly from the get go.  If they don't meet and you need to move a run then it will fail.
To do that you may need to:
- create some guidelines before hand if you draw the ramp using runs and landing
- or, draw the ramp by boundary sketch, not runs
However, for a cleaner rail transitioning (both in Revit and fabrication), it is advisable to NOT have the runs meet exactly at a corner, and have landing extension on one or both sides.
