Help with locating the cause of "Serious Error" within the Journal File
DONeill1987
Message 1 of 1
DONeill1987
Hi All. My Revit model has been getting the "A serious error has occurred. It is strongly recommended that you save your work in a new file before continuing". I seem to have tried all answers found on this forum in relation to this issue, with no resolution being found.
As I would not be fully able to understand the contents of Journals as yet, I am posting to see if anyone is able to spot what might be the cause of this error.
I have attached the latest Journal File, and look forward to seeing if this annoying issue can be solved!!
Replies (0)
