Help with inconsistent units in formula
youssef.ibrahimM37J6
Message 1 of 8
As part of my schedule, I am trying to create a new parameter equal to elevation from level + 60000.
However, I am not sure what the problem is!!
Accepted solutions (3)
Replies (7)
Message 2 of 8
L.Maas
I expect the elevation from Level has unit of length. Now you want to have a number. Revit does not know how to convert length to number.
Normally you can fix it by dividing. So "Elevation from Level/1 + 60000".
Basically Revit than will divide "Elevation from Level" by 1 (Revit assumes length unit) converting it to a number. Sometimes you have to play around with it or force it more (e.g "Elevation from Level/1 mm + 60000) to get it to work.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 8
Thank you @L.Maas for your reply, but the column return does not return anything in the cells
Message 4 of 8
Mike.FORM
If you are making your calculated parameter a 'length' type you should not need to divide by 1.
You only need the division when you had it set to a 'number ' type so that it removes the units.
Message 5 of 8
kostask_oionei
take a look below. Both work.
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
Message 6 of 8
anze.kumar
Take a look at your "Formatting" dialog in schedule -> maybe there is a problem there, as it is not showing any value in the schedule cell
Message 7 of 8
L.Maas
I expect you have grouping on, "Itemize every instance" unchecked on the sorting tab of the schedule. In that case Revit will not automatically add up the values. On the Format tab you will have to activate a calculation method on that particular field to get values in the column
Louis
Message 8 of 8
@L.Maas and @kostask_oionei  thank you it works fine now
