I have a curtain panels schedule
The problem is the height of the curtain wall is many levels high.
And when I go to schedule, the panels are all listed in the base level of that curtain wall
How can I show in my schedule the amount of panels per floor
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von Alfredo_Medina. Gehe zur Lösung
Curtain panels don't have a level parameter. Most likely because they are hosted elements. So, the wall host has the level's name, not the panels. You need to add the level's name to the panels, manually. From an elevation view, select one panel and then do > right click > select panels > on horizontal grid. Then, in the properties panel, write "Level 1", for example, in the Comments property of the panels. Then add "Comments" to the schedule of panels.
Try to use a basic wall type in lieu of the curtain panel and see if they report the level correctly.
