Help with IF statements and calculated parameters
bmyrumYGWJ2
bmyrumYGWJ2
I am trying to get a door to show two values depending on the occupant load (Count). I have an equation that gets me the required door width but since the minimum is 32" I need to say 32 unless it is larger.
If the occupant load Required Width requires less than 32" I want it to say 32.
If the occupant load Required Width requires more than 32" I want it to say the value
(Count * Factor) is the calculation for our Required Width
If ((Count * Factor) < 32 , 32 , IF (Count * Factor) > 32, (Count * Factor))
I don't know if I am doing too much in one equation or just not getting my statement correct. I have made this work with windows before but it has been awhile.
Does this make sense?
You're not doing too much.  Embedding IF statements is pretty common.  What error is being thrown?
Why the embedded If Statement? Wouldn't "If ((Count * Factor) < 32 , 32 , (Count * Factor))" yeild the same result?
Ah, I see.  You need an additonal result at end.  If true: do this. If not true: do this.
If ((Count * Factor) < 32 , 32 , IF (Count * Factor) > 32, (Count * Factor), DO THIS))
if((Count * Factor) < 32, 32, (Count * Factor))
