Help[ with Hatch Pattern
Sahay_R
Mentor Mentor
Message 1 of 8
Sahay_R
I had used an AutoLISP routine (from RevitIQ) to generate a hatch pattern. The process involved drawing the required pattern in a 1"x1" square in AutoCAD, then running the routine. When I try to add it to Revit, I get this error message -
This is the pattern that I was aiming at -
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Replies (7)
Message 2 of 8
Have you tried to reduce the Import scale?
Message 3 of 8
Sahay_R
Doesn't work. The CAD drawing is in a 1"x1" box. I did try to scale the pattern up and trim it to fit into the box - no good.
Rina Sahay
Message 4 of 8
Can you share the pat file?
Message 5 of 8
Sahay_R
Absolutely. Also the DWG.
Rina Sahay
Message 6 of 8
Doesn't work. I would suggest import the CAD file in as drafting lines and use Hatch Kit add-in to create the pattern. I have no experience with the program you are using.
Message 7 of 8
hugha
The attached fill pattern will load to Revit as a Drafting Pattern when scaled between 0.1 to 0.5.
You can then use the free HatchKit Add-In for Revit to create a model fill directly from that loaded pattern at any scale of your choice.
Message 8 of 8
Sahay_R
Thank you!
Rina Sahay
