Message 1 of 8
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I had used an AutoLISP routine (from RevitIQ) to generate a hatch pattern. The process involved drawing the required pattern in a 1"x1" square in AutoCAD, then running the routine. When I try to add it to Revit, I get this error message -
This is the pattern that I was aiming at -
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
