Hello all, I am modifying an existing bulkhead family that I have 'inherited'. Here's the deal - I have 4 'boxes', out of which one is controlled by a visibility parameter. I have created an IF/THEN formula to drive the overall length of the assembly - if Bulkhead 4 is not visible, then the Overall length will adjust accordingly. This has led to all kinds of mayhem - the numbers are correct, but the geometry does not obey. Family is attached.
Assistance would be appreciated!
Solved by Sahay_R. Go to Solution.
Solved by barthbradley. Go to Solution.
Solved by ToanDN. Go to Solution.
the ceiling sketch collapses on itself. I don't see how you could make the ceiling monolithic and flex the way you want it to. Looks like you need 2 ceiling conditions; 1 visible when 4 and 1 visible when 3.
...BTW @Sahay_R: How's life at the top? You seen that Expert Elite translate to a bigger paycheck yet?
Thanks @ToanDN and @barthbradley for the sage counsel. What I had inherited looks like an in-place model that was exported out to RFA - hence the mess. I have removed the four-bulkhead situation completely. The good outcome has been that that it is easier to control the dimensions of the geometry than it was before. I will propose a second family with 4 bulkheads. Or maybe create one with two type parameters. . You know me - can't keep it simple!
@barthbradley - the only outcome of 'being at the top' - as you put it - has been an enhancement of the size of my head!
