Help with Family Templates
Hi All,
I am working with Revit 2017, and recently, on opening the software I get a message about Templates (see attached).  I want to create a Family, and when I select NEW - FAMILY  I get only the folder options attached which looks unfamiliar to me.
I have attached screen shot.  I am unsure what I have done as I have created many families in the past but possibly with a previous version of Revit.  I cannot remember creating one yet with 2017.   I have linked UK content folder which contains all import families and that is working fine (the is the YEAR 3 - UK Screenshot)
Thanks - if you need more screen shots let me know.
My current set up attached below for Family Template in File Location which links to UK content folder families such as Furniture, etc.
artejon
The default path is for family templates (.rtf). I assume you put your own families (.rfa) which are not family templates in D:\YEAR 3\UK. If there aren't any .rtf files there then you will get the warning.
Revit add-ins: CAD Purger (delete UNUSED and selected line patterns & line styles, find and delete CAD), Rooms To Spaces, Schedule Utilities (Calculated Values/Combined Parameters To Tags, reuse view filter rules in schedule filters), View Filter Manager at Revit Apps Store
AJA14
That is not the standard file location for family templates. What your screenshot shows first is the location of the templates and not the family templates. The family templates are usually location in the C: drive > Program Data > Autodesk > Revit 2017 > Templates. Unless you have a different deployment setup to a server location, that's where your family templates are and you should browse to them and make sure revit goes there when you try to create a new family.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
