Help with adding a floor plan level
after adding a basement level a structural plan showed up so what i'm i suppose to do with it?
Are you saying you accidentally added a Structural Plan View instead of a Floor Plan View? Then delete it and create a Floor Plan View.
ennujozlagam
@Anonymous hello, just copy level in your sections or elevations > go to view > plan views > floor plan select the level you added. thanks
Viveka_CD
Hi @Anonymous
I see that you are a new visitor. Welcome to the Autodesk community!Smiley Happy
I'm assuming you added a structural plan from the drop-down menu.
Go to Click View tabCreate panelPlan Views drop-down, and then click
  •  (Floor Plan) - this is what you need
  •  (Reflected Ceiling Plan)
  •  (Structural Plan)
Plan viewPlan view
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. Kudos welcome!
