Help organic roof structure
admeza
Message 1 of 14
admeza
Hi! I did this shape in Rhino and now I'm trying to do it in Revit with Conceptual Mass, but I can't, mostly because of the holes on it. I tried to do it in a single line, leaving small holes between them, but look what it creates. At the end, I want to have the mass in Revit to do then the tridimentional truss.
Captura de pantalla 2022-10-15 014557.jpgWhat I want to createWhat I want to create
What it creates with the dots that I have thereWhat it creates with the dots that I have thereI tried to do this with Bezier SplineI tried to do this with Bezier Spline
Replies (13)
Message 2 of 14
Model without holes then use voids to cut the form.
Message 3 of 14
admeza
I tried that, but it didn't work because I can't make a hole inside of the mass. Captura de pantalla 2022-10-15 022525.jpg
Message 4 of 14
Not sure if I understand. Why can't you make the voids and the surface in the same mass so you can cut?  Do you want to share the file?
Message 5 of 14
admeza
Yes, here it is. I'm new in Revit, so if you know like an option or how do I do the voids, I would aprecciate it.
Message 6 of 14
Edit the mass and add void form.
-  draw lines and create solid form first so you can size it more easily
- Then change it to void and it will cut the surface
Message 7 of 14
admeza
Thanks for the help, I did it and it worked. But now, the other problem 😅 of the tridimentional truss. I did a family for the structure of the panel with the template Metric Curtain Panel Pattern Based, and I load it in the project days ago to test it. And now when I try to load it in the project that I created, it appears an error. I tried to save it with another name and also created a new one from scratch.Captura de pantalla 2022-10-15 134402.jpgerror3.jpgError.jpg
Message 8 of 14
Where is the family?
Message 9 of 14
admeza
The file? Here it is.
Message 10 of 14
You can test the family flex by changing the  tile spacing.  Here shows some points are not hosted/constrained properly.
I fixed the points and skeleton frame for you.  You can recreate the rods from them.
Message 11 of 14
admeza
The one I did at the beggining when it worked, but now doesn'tThe one I did at the beggining when it worked, but now doesn't
Complete it the one you sentComplete it the one you sent
I completed the one you sent, but it keeps appearing the error. And also tried with the one that I did first, but it doesn't work either.
Message 12 of 14
I have fixed your curtain pattern family again but I would recommend to use an adaptive generic family with repeater.  It gives a better result.  Both are attached and the image below is using the adaptive family.
Message 13 of 14
admeza
OMG! I tried to do it with an adaptative family too, doubling the mass with a subdivision, placing the family and then press repeating, but it hasn't gave me a result. Would you mind telling me step by step how did you do it?
Message 14 of 14
admeza
This is the file I'm using.
