- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi fellow Revit/BIM mates,
I need some help in regards to this issue that I have now on Revit as I am currently facing a deadline for the final model in 2 days time. Really appreciate it if anyone can help me out!!
Issue:
I was just working on my model few days back and suddenly today the entire Revit turn blank (picture 1) after I have decided to save and reopen the file. Everything else can be seen like properties box and things like that. Anything other than the model (which includes all the grid lines and section and the 3D icon box that can usually be found on the top right hand corner of a model in a 3D view) can be seen. Tried drawing and modelling on Revit itself, nothing shows up too. Zoom to fit doesn't work as well. It is as if that the model for Revit is invisible. All the information on the drawing is invisible because when I hover my mouse over, I can totally see that the item/model is there (picture 2). All shortcuts worked fine and visibility is checked. I do not know what is wrong..
What I have tried doing & didn't work:
-Opening a new Revit file (new model & new family creation) , nothing shows up. Gridlines for Ref view can't be seen as well.
-Restarting Revit by closing all Revit related files and opening them again
-Select all of the items in the model, delete it and undo.
-Update Windows software
-Restarting my computer
-Search Visibility settings (but all the setting is in order)
-Update Java
-ZF function
-Drawing a model and nothing shows up, no line, no nothing
Would really appreciate any kind soul to help me on this. If you have ever encounter this problem and solve it please help out a fellow Revit mate!
Thank you in advance!!!!
