HELP HATCH PATTERN
HELP HATCH PATTERN
Message 1 of 12
HELP HATCH PATTERN
Anyone can help me on this i need 240X160X3mm gap but i can't get this pattern in revit
Replies (11)
Message 2 of 12
hugha
Try this:
; Written by HatchKit Team Edition
; HatchKit Team Edition (c)1990-2019 Cadro Pty Ltd
; www.hatchkit.com.au/
;-Date : 2020-02-06
;-Time : 21:54:56
;-HatchKit Team Edition Version : 3.1.11.2776
;-HatchKit Team Edition Output Filetype : Revit with HatchKit Add-In
;%VERSION=3.0
;%UNITS=MM
*160x240+3,RUNNING HORIZONTAL 160 x 240 w 3 mm gap
;%TYPE=MODEL
90,0,0,243,81.5,240,-246
0,0,240,-81.5,-243,160,-3
-90,160,240,243,81.5,240,-246
180,160,0,81.5,243,160,-3
hth,
Hugh Adamson
Message 3 of 12
You can use PyRevit, and you can make the pattern easily with it. https://pyrevit.readthedocs.io/en/latest/pyrevit/init.html
Message 4 of 12
indiana_j0nes
Hey @Anonymous
I would suggest https://pattycake.io/pat
Check it out.. its online and very intuitive..
Its a really great tool.
Cheers, K
Kunal Tuljaram Gaidhankar
Message 5 of 12
Really appreciate your help but the pattern is wrong my is running vertical can u tell me how u do it because i have HatchKit too free version
Message 6 of 12
i have try it up but how to i know the dimension?
Message 7 of 12
martijn_pater
See attached (made using PyRevit).
Message 8 of 12
Pattycake_Kyle
Made with our DXF to PAT generator. If you are having problems with understanding the platform, please reach out hi@pattycake.io --- we are always looking for ways to improve the service 👍
One complex (with 3mm grout): https://pattycake.io/official/pat/YlVLdmAXyEM
One simple (without grout): https://pattycake.io/official/pat/v2A3m8vw18e
Think you might want to use the without grout for documentation... 3mm joints are a bit too dense and wont read depending on scale. The simple one has tiles 163x243 to accurately represent CL of grout to CL of grout.
Pattycake, PattycakePattycake, Pattycake
Cheers 🎂🎂🎂🎂🎂🎂🎂🎂
www.pattycake.io
Web based & real time .PAT creator. The largest collection of free PAT files! Over 700+ Pat files ready to download
No plugins or add-ins to install, and Revit compliant!
Message 9 of 12
hugha
My apologies for the delay in providing this corrected pattern:
;%VERSION=3.0
;%UNITS=MM
*160x240+3
;%TYPE=MODEL
180,0,0,163,121.5,160,-166
90,-160,0,-121.5,-163,240,-3
0,-160,240,163,121.5,160,-166
-90,0,240,-121.5,-163,240,-3
The pattern has four grids as it is arranged with offsets set at angles to place the tile repetitions naturally.
Patterns built with orthogonal offsets typically require more definition lines to complete the pattern as demonstrated by patterns created with generators requiring the pattern sample to be built within a rectangle.
This, the earlier pyrevit pattern from martijn.pater as extracted from the  .rvt file contains 10 grids.
;%VERSION=3.0
;%UNITS=MM
*Tiles 160x240mm-3mm gap,HatchKit Fill Manager
;%TYPE=MODEL
0,0,0,0,-243,160,-166
90,0,0,0,326,240,-3
180,160,240,0,243,160,-166
90,160,0,0,326,240,-3
0,163,121.5,0,-243,160,-166
90,323,121.5,0,326,121.5,-121.5
90,163,0,0,326,118.5,-124.5
180,323,118.5,0,243,160,-166
90,323,0,0,326,118.5,-124.5
90,163,121.5,0,326,121.5,-121.5
hth,
Hugh Adamson
Message 10 of 12
martijn_pater
@hugha wrote:
...contains 10 grids.
I seriously doubt he's going to cover acres with that tile pattern. I'm all for keeping files as clean as possible, but I would question at what point that would actually become noticable… I appreciate the 'critique' though, so perhaps next time I'll run it through Hatchkit.;) Did you use that to extract the hatch aswell?
Message 11 of 12
RDAOU
@Anonymous
Considering that I hate cosmetic add-ins and do not really like PyRevit's coding … the below was generated in excel 😛 .Pat file attached...however, 3mm is pretty much too small to show up in your print outs unless you are printing scale 1:5 to 1:1 !!
;%UNITS=MM *Staggered_Vertical,160x240 3mm Joint - RDAOU ;%TYPE=MODEL
;;********************************************* 0,0,0,0,486,160,-3 0,0,246,0,486,160,-3 0,81.5,243,0,486,160,-3 0,81.5,489,0,486,160,-3 90,0,0,0,163,-246,240 90,-3,0,0,163,-246,240 90,81.5,243,0,163,-246,240 90,78.5,243,0,163,-246,240
Message 12 of 12
hugha
>I'm all for keeping files as clean as possible, but I would question at what point that would actually become noticable.
Two occasions where it can are
1.  in sussing how the pattern can repeat exactly within a enclosing rectangle in the first place.
2. where solving the above results in a much heavier pattern than one with no internal redundancy.
And yes,  HatchKit can extract fill patterns to text files 🙂
