Help! Creating a staggered stud wall assembly
emilys27ZKX
emilys27ZKX
I am trying to create a staggered stud wall assembly similar to attached picture.
I cannot figure out a way to create this condition from the edit assembly menu. I also haven't been able to find any resources online. Has anyone else found a work-around or solution to show staggering studs? Open to suggestions!
Create a wall type assembly with a 5 1/2" wood core, name and description properly to say what it is with the required STC value.  The staggered studs should be taken care of by a detail or a wall legend.
emilys27ZKX
Makes sense, thank you!
