Help creating a parameter which can show current height of an element (Revit 2022)
jsalinasD7N59
Observer Observer
jsalinasD7N59
Observer
Observer
Hello, I'm trying to create a power outlet family which can have a "text" that reports the current height of the outlet. I've tried by inserting an annotation type family which can report the values of a height associated via a formula. Whenever I try filling the required formula it says "Inconsistent Units". I was wondering ig there is a smarter approach for my issue.
You can't. But what about a Tag?
jsalinasD7N59
Observer
Observer
Yes! That works even better, my only issue is that we usually work with feet and fractional inches, but when it comes to fixture heights we use inches. Is there a way to make the tag report that height in inches without modifying the overall project units?
By the way, many thanks for the solution!
Edit the tag label > format units > and change it to inches or fractional inches depends on your standards.
You're welcome.
Make sure you mark my post as the Accepted Solution.
