Help converting 3d dwg to revit family
Can someone please help me convert a washer and dryer from a 3d obj/3d dwg to revit families please? When I try to import or link, it stalls at 40% every time and stops responding. I'm using Revit LT and don't have any other programs to mediate.
https://www.askona.com/dryer/t411vdw
https://www.askona.com/washer/w4114cw
(These are the T411VDW and W4114CW downloads from Asko, I reached the max trying to link both zip files.)
Thanks!
PavelAnd
There in no Revit nearby now. May be you can install a trial version of Revit2020 and try to import? It may be faster...
Best regards, Pavel Plotitsyn.
What "3Dobj" or "3d dwg" are you  referring to? There's none available at the Links you provided.
At the bottom of the each page there is a download link called "3D Drawings" which downloads the zip folder. I couldn't attach the zip in my original post because they are too large.
The drawing was converted from a very detailed 3d model with all the nuts and bolts and dust and whatnots.  On top of that it was converted to meshes or poly surfaces instead of ACIS Solids.
I wouldn't import a 45MB drawing of a washer to a Revit family.  Even if you can, it will bring Revit to its knee when you load the washer in your project.  There are plenty of W/D Revit models from other manufacturers or even generic that is much more smaller/cleaner and even packed with useful parameters.
Attached TD85-Logic-V-XL-W-3d
WM85-Logic-XL-W-3d.rfa  Attached
