Help can’t hide Interior edges in parts!
Message 1 of 25
Hi hope someone I a suggestion.
When I want to make parts on floors, all the interior edges shows up, like shown on the picture. The only solution I have find so far is to hide each line by Linework tool. It can take a lot of time.
By the way I have unchecked “interior edges” in V/G.
Is there a smarter way to remove these lines, so it only shows the parts division lines?
Replies (24)
Message 2 of 25
Did you try to set Parts Visibility on Show Parts, may be you had set it to show both?
Message 3 of 25
Thanks for the quick answers. But I have tried set Parts Visibility on Show Parts and still have the problem.....
Message 4 of 25
It works for me.  Can you attach your file?
Message 5 of 25
ok that is strange! But here is my file.
That could save me for hours of work 🙂
Message 6 of 25
I don't understand. When you say "Interior Edges", are you meaning "Common Edges".  Parts don't have Common Edges.  Those lines in your picture looks like Cut Pattern linework, in which case you'd remove by overriding Cut Pattern in view's VG.
Message 7 of 25
...I'll add for clarification: Control the Visibility and Graphics via the Parts Category-- not the Floor Category.
Message 8 of 25
Hi barthbradley
Thanks for the answer. I used the word “Interior Edges” because it lies in the same place as the “Interior Edges” on the floor (on the Floor I can turn them off in V/G under Floor - Interior Edges). But when I use Parts the lines show up again. (Just for clarification, I mean the yellow lines in the attached file)
As I can see the only thing, I can control under V/G - Parts are – “Hidden lines”. And that makes no difference.
Then I tried to change the “Cut pattern” but it changed nothing. The only thing there change something is by modify the “Projection lines” but then I change all lines.
Please tell me if I do something wrong!
Message 9 of 25
Open the views Visibility and Graphics dialog box (VG). Scroll down to Parts category and untick "Visible" in Cut Pattern Overrides. That do it?
Message 10 of 25
Sorry, but it does not help
Message 11 of 25
Dang it! I thought for sure, that would do it. Oh well.  Can you post a file to look at?
Message 12 of 25
Here 🙂
Message 13 of 25
Here 🙂
Message 14 of 25
Go into Graphic Display Options and uncheck Show Edges.
...Must be Friday. I get it now. You're referring to the Floor Plan view.  Well then: Linework tool it's got to be. Sorry for the confusion on my part (no pun intended).
Message 15 of 25
Are you talking about the yellow or the red lines?
Message 16 of 25
The red lines, sorry about the confusion
Message 17 of 25
...Yellow, Red? but all the lines represent slope hinges.
Message 18 of 25
The red lines are the intersection between different sloped planes and they are showing correctly.  If you want to hide them for some reason then yeah you have to use Linework tool to fake it.
Message 19 of 25
But I can hide the slope lines when they are on the same floor without the Parts! Under VG – Floors – Interior lines.
I just hoped that something was possible!
Message 20 of 25
Not sure why you just don't show both the Original and Parts in your Parts View (if it is in fact a Part View), and then remove those offending Parts (or hide them) to reveal the Floor. Then turn off Interior Edges.
