Hello! Please help me with the problem. How to set the connection type of slab layers? If you connect the upper and lower floors, then all layers go in steps. One layer needs to be variable. as pictur
lilya.barsukova.01
Message 1 of 9
lilya.barsukova.01
Replies (8)
Message 2 of 9
Like this?
The bottom floor is shaped edited:
Cut the bottom of the top floor with an In-Place Modeled Void.
Message 3 of 9
lilya.barsukova.01
I want the bottom face to be sloped. With these settings, it is smooth
Message 4 of 9
Yes. I get it.  I explained how to get there in my first reply. Cut the floor with a void.
Message 5 of 9
lilya.barsukova.01
Please note that I have a bottom layer. The void will cut it out too
Message 6 of 9
lilya.barsukova.01
I would like to know if it is possible in this situation to specifically adjust the layers for variability? So that the display of the lower layer is preserved, and the upper one is on the slope. Is it possible?
Message 7 of 9
YOU NEED TO CREATE 2 FLOORS.
Message 8 of 9
Yes, it is possible - as I have shown above.
...assuming you have full Revit and not LT.  Which one do you have?
Message 9 of 9
lilya.barsukova.01
full. Understood. I was hoping there was an easier way, but it doesn't seem to be. Then you'll have to cut. Thank you
