Helix Staircase
49bsinkey
Helix Staircase
49bsinkey
I trying to make a steel helix staircase with a laser cut pattern on the phase of the stringers. I tried making a modified family profile for the striger but I can't figure out how to draw it with the pattern.
dzanta
a stringer in a revit stair is a profile that is swept along the curved path of the stair.  I tried making a custom baluster with an object that might cut/join the geometry but it didn't work.
I will research this and get back to you.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
49bsinkey
Ok, thats good to know. I'll mess with that and see if a can also find another way. Thanks for the help!
constantin.stroescu
it could be a way if you use a material with cutouts. These will be shown in Realistic and RayTrace Visual Styles and also in Render ( computer Render , not in Render in cloud because cutouts it is a procedural map)
For this , select the Suppports - Stringer > Properties > Edit Type > Type Properties > Materials and Finishes > Material - chose a metal material and make a copy of it so to create a new material . From Appearance , use Cutouts . You an create ( preferable in Photoshop) your own black and white pattern (white is opaque and black transparent)
Anyway this effect an be obtained much better in 3ds MAX , where the mapping of the texture is more developed.....
Constantin Stroescu
49bsinkey
Great! Thats going to be very useful. But Im not sure if it works for the type of pattern I and trying to do on the stringer. Its a little complicated and its  specificly for the stringer.
49bsinkey
