I trying to make a steel helix staircase with a laser cut pattern on the phase of the stringers. I tried making a modified family profile for the striger but I can't figure out how to draw it with the pattern.
a stringer in a revit stair is a profile that is swept along the curved path of the stair. I tried making a custom baluster with an object that might cut/join the geometry but it didn't work.
I will research this and get back to you.
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
it could be a way if you use a material with cutouts. These will be shown in Realistic and RayTrace Visual Styles and also in Render ( computer Render , not in Render in cloud because cutouts it is a procedural map)
For this , select the Suppports - Stringer > Properties > Edit Type > Type Properties > Materials and Finishes > Material - chose a metal material and make a copy of it so to create a new material . From Appearance , use Cutouts . You an create ( preferable in Photoshop) your own black and white pattern (white is opaque and black transparent)
Anyway this effect an be obtained much better in 3ds MAX , where the mapping of the texture is more developed.....
Constantin Stroescu
Great! Thats going to be very useful. But Im not sure if it works for the type of pattern I and trying to do on the stringer. Its a little complicated and its specificly for the stringer.
Thanks for the help!
