Hello every one
Since I have made changes to the exterior wall of revit ( I have perfored the wall ) the revit file became so heavy
I can move or duplicate this wall after houres of waiting
I was asking how to solve this problem
Solved by barthbradley. Go to Solution.
Is those square hole wall profile edit or it is family void embedded into the wall?
I have created a wall then I have edited the profile making the holes by myself
I wouldn't do that. Instead, apply a Material with a perforated Appearance Asset to a non-perforated, solid panel.
try to make a perforated wall as a family. thanks
