Heating and cooling load calculations based on material thermal properties
I am trying to understand the heating and cooling load calculation using building elements (roof, walls etc.) thermal properties like U value, R value etc.
For this
  • I built simple model of four walls, roof and floor.
  • Thermal properties of building elements
  • My energy settings are as below. Note Detailed Elements is checked.
  • No override is selected in Schematic Types
  • Heating cooling load window is as below
  • Now whether I Check Detail Elements box in Advance Energy setting or I uncheck this box, I get the same results. This means calculation is always based on "Conceptual Types" and selecting "Detailed Elements" check box is not making any difference.
  • Conceptual Types parameters are as below which are different from thermal properties of building elements in the model.
  • My question is that what I am doing wrong that I am not getting heating and cooling load calculations based on material thermal properties specified for building elements?
Corsten.Au
I would suggest go through some tutorials before using Heating and cooling load calculations..
Corsten
Building Designer
