Hatching rotation does not work in Revit
_Mary_marya_
_Mary_marya_
Hello! At some point, the hatching rotation in Revit stops working! What could this be related to? The settings are all standard!
mhiserZFHXS
Not sure what your image is supposed to be showing.
Are you using model patterns instead of drafting patterns?
_Mary_marya_
Any modeling hatching does not rotate on floors and walls!
Mike.FORM
When rotating make sure 'Copy' is turned off.
mhiserZFHXS
I understand but is there something extra the image is showing? It looks like you're in the middle of the rotate command and haven't clicked to finalize it.
_Mary_marya_
Thank you very much! I've already reinstalled windows 3 times because of this, I couldn't find the reason!))
