hatch with variable spaces
Irreb
Message 1 of 10
Irreb
hi,
how can i create a hatch with a custom pattern made up of horizontal lines (with infinite length) at different steps from each other using the txt file.
i searched about in the help.autodesk but it doesn't explain this particular about different steps.
example i need something like this:
________
________
________
________
is it possible to do?
Replies (9)
Message 2 of 10
Sahay_R
Look for the .pat file on your machine. Open it in Notepad, save a copy of it. This gives detailed instructions about how to do this.
What I do is take a pattern which is similar to the one I want.Save the file, remove what you don't want. Follow the syntax correctly. Your hatch pattern will be made out of 4 lines = 4 families. Each line will be something like this -
0,         0,         0,         0,        1
0,         0,         0,         0,        2
0,         0,         0,         0,        3
0,         0,         0,         0,        4
the last number  = the distance between the lines. So this will vary.
the first 0 = the angle that the lines are at. So if your pattern runs at an angle of 45, then the first 0 will be replaced by 45.
When you are editing the hatch patterns, go into Custom, load your new file. Test it until it works. This would be a fairly simple pattern, so it should not be too much of a big deal. Good luck!
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 10
hugha
HI, this pattern has four unbroken horizontal lines at varying spacings with an overall pattern repetition cadence of 100".
;        Written by HatchKit for Revit
;        HatchKit for Revit (c)1990-2017 Cadro Pty Ltd
;        www.hatchkit.com.au/
;-Date                                   : 2017-03-05
;-Time                                   : 7:20:10 PM
;-HatchKit Version                       : 3.1.10.2719
;-HatchKit Output Filetype               : Revit with HatchKit Add-In
;%VERSION=3.0
;%UNITS=INCH
*vaying
;%TYPE=MODEL
0,0,12,0,100
0,0,25,0,100
0,0,50,0,100
0,0,87,0,100
if that is too regular then you can mix it up further by individually altering that 100" spacing:
;-Date                                   : 2017-03-05
;-Time                                   : 7:20:10 PM
;%VERSION=3.0
;%UNITS=INCH
*vayingmore
;%TYPE=MODEL
0,0,12,0,95
0,0,25,0,107
0,0,50,0,113
0,0,87,0,133
Add even more lines if you wish.
BTW the free HatchKit Add-In for Revit will allow the specification of this simple style of pattern entirely within Revit.
http://hatchkit.com.au/files/file/hatchkitaddinforrevit.zip
hope this helps,
Hugh Adamson
www.hatchkit.comn.au
Message 4 of 10
i need a hatch patter with two  lines (one is half of the other) in a rectangle which will gradually tapers two zero.
Message 5 of 10
semhustej
You can watch first few minutes of this tutorial, it explains the basics of hatch creation:
https://www.youtube.com/watch?v=bh9yhiKohlo&t=2046s
Message 6 of 10
Pl. see the attachment.
Kindly suggest the remedy.
Message 7 of 10
pl. find the attachment.
Message 8 of 10
hugha
That cannot be readily done by simply hatching within AutoCAD.
IIRC there is a tool in Civil3D that handles such markup for slopes and batters.
hth,
Hugh Adamson
Message 9 of 10
Sahay_R
Also - try using PyRevit. It’s a free Revit add in that allows you to create ANY. kind of fill pattern. And it has a bunch of other cool tools as well.
Rina Sahay
Message 10 of 10
_Vijay
Or you can create custom pattern in Revit with help of pyrevit.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
