hatch variation with detailing degree
Hello!, how do you vary the type of hatch, automatically, according to the degree of detail? (for walls for example, material based)
Sahay_R
There are two kinds of hatch - Drafting and Model.
Drafting hatches are very small scaled and are good for details. They will adjust per the scale of the detail. Most components - walls, etc - will come in with their own material hatches.
Model hatches are full scale and are meant to be applied to the model.
Anything specific that you are trying to achieve?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Hi Rsaray, i post on picture to help explain,is possible to auto change to another kind of hatch, when i change of high to low detail? actually when pass to low detail the hatch just dissapers.
Sahay_R
Also - when you switch from High to Medium to Coarse level of detail, Revit will hide hatches.
Where did the hatch come from? Is it from the wall style or is it a filter that has been applied on the walls?
Can you share the file?
Rina Sahay
Coarse detail level: wall hatch is defined by edit wall type and change Coarse scale cut pattern.
Medium and fine detail levels: wall hatches are defined by the layer materials. To change them, edit the materials.
