Hatch Pattern Visibility
SLDBrown
SLDBrown
Hello All,
I have views that are template controlled. My discipline is Mechanical so all of my architectural objects are shown as half tone (I am okay with this). My issue is, there is a hatch pattern that I need to turn off on my floor slabs. How can I do this? See attached.
Accepted solutions (3)
CoreyDaun
You can turn the surface pattern off for specific Categories by going to Visibility/Graphics Overrides (for your View Template), clicking "Override..." under 'Projection/Surface: Patterns', and clearing the checkbox "Visible".
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
constantin.stroescu
Because the file has applied a View Template you are at the moment unable to override the floor properties.
I suggest to Duplicate the View and in the new View :
  1. Properties >Identity Data > View Template > click on right side button - Apply View Template window appears > Name - choose None - Apply and OK
  2. Properties > Visbility/Graphics Override >Edit > in the new window - Model Categories > Floors > Projection /Surface > Patterns  > Override  > Fill Pattern Graphics > Pattern Overrides > Uncheck Visible
Constantin Stroescu
SLDBrown
Thanks so much for the reply. It worked.
Steven Brown
HDR Engineering, Inc.
Water Business Group
CADD Technician II
4061 Powder Mill Rd, Suite 620 | Calverton, MD 20705
p: 301.289.7210 c: 443.510.1627
Steven.L.Brown@hdrinc.com | hdrinc.com
Follow us - Facebook | Twitter | YouTube
