Hatch pattern orientation
Message 1 of 9
Hello all,
Is there a way to apply a wall hatch pattern so it is oriented with the direction of the wall rather than globally?  This is a drafting hatch not a model hatch...
I have an interior wall that I created a view filter for per the parameter in properties.  It works good until I get an angled wall.
Thanks in advance...
Jleibold
Replies (8)
Message 2 of 9
ChrisNeedhamNZ
Yes there is. See the attached image.
Chris Needham
Whangarei
New Zealand
Message 3 of 9
Chris - thanks for the reply
I understand that I can set the fill pattern for model, but I need it to be drafting.  Here is what I am doing.
I have several parition walls on my floor plan.  In a different floor plan view, I want to do something else. I have a instance parameter for the walls so I can designate each partition wall with a different hatch.  I use a view filter that will show a hatch based on the instance parameter attached to the wall family..
So, for example, if I have partitiion wall that is 1A, show this hatch, 2K, show that hatch.  I did not want to create a different wall for each type since they are all "partition wall" family.  I thought I could keep it simple by just using one wall type with instance parameters. Using the fill pattern for model, yes it works but that is for a material in cut pattern and that is a model fill pattern. When using the view filter fill pattern is for drafting.  I select "aligh with element", but it will not adjust.
Does that help?
Jleibold
Message 4 of 9
loboarch
The image posted is not showing a change to use a model pattern. It is showing the setting for a fill pattern host orientation. The fill pattern itself can be set to rotate as the host rotates.
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-02C84BD3-8CFC-40D4-8E21-A195A3C0BB2B
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 5 of 9
loboarch,
Thanks for the link....
SO, since this is a drafting fill pattern, I can't do what I want wit the view filter? Correct?  Or am I missing something?
I have tried all three options...
Message 6 of 9
loboarch
Visibility and Graphics overrides will not affect the host orientation settings of a fill pattern. (Even though the control is there, probably should be grayed out?) To do this with a visibility and graphic override you will need 2 fill patterns. You could then use an override with the filter to apply the "alternate" fill pattern that is oriented to the host element.
I did not verify this will work, but it should.
Why does it have to happen with a filter? Why not just change the fill pattern ot orient to the host globally?
Jeff Hanson
Revit Help |
Message 7 of 9
Revisiting this issue...
I have gone back to this project & have tried to "keep readable to host layer" by changing...
Manage>Settings>Additional Settings>Fill pattern - no luck
I made sure that the material was correct and had the same fill pattern assigned to it under projection and cut - no luck
I have read this http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-02C84BD3-8CFC-40D4-8E21-A195A3C0BB2B   - no luck
this works.....
doesn't work.....
kinda works...
The steel beam image is not at an angle - works.
The other two are lintels...
This is a drafting view fill pattern located in the material.....
All the filters have been remvoed
I cannot make this work on an angled object - using a cross hatch pattern -
At a loss as what to try next....
I know this should be very simple and straight forward but...
Jleibold
Message 8 of 9
greghHW3PE
Best answer is Revit sucks
Message 9 of 9
fifer.j
You should go into the wall family itself, edit type> edit> click three dots next to material desired to change> click cut pattern in material browser dialogue box> click the pencil to edit> then click Orientation drop down to orient to element. This is a drafting pattern. You sadly can't change to a wall pattern to a model pattern.
