Areas and Sections in Color
Hello everyone,
Ive run into 2 problems with color.
I attached 2 pictures of the issue. I tried everything I could think of. Sadly to no avail. The trees shouldnt be blue. And the Section line shouldnt be blue.
Hope to find the solution here, any help would be greatly appreciated. Thanks in advance!
Kimtaurus
The blue colour of the section head is to indicate that this annotation links to a view. It won't print blue, but black (if this is the colour set in Manage > Object Styles > Annotations > Sections).
The blue from the trees: tihs may also be due to the setting in the projects Object Styles. Again go to Manage > Object Styles > Model Objects > Site.
See if there's a material applied. Or go to Visibility/Graphic overrides, there could be an override in the Site category.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
Well i actually tried it now and its all set to black but the problem remains. And is actually printed in Blue sadly. Do you have any other possible sollution?
L.Maas
In the Print Setup window there is an option "View links in blue" maybe that is set?
Louis
Please mention Revit version, especially when uploading Revit files.
