Hatch pattern does not display correctly.
brylamichal97
brylamichal97
Hello!
I've problem with displaying of hatch pattern in dwg file after the exporting from revit file. I created Model Text (3d) and set the material with <solid fill>. Unfortunetly, when I exported to dwg file it doesn't show how it should be. I attached images how it looks like. Do you have any ideas what's the problem?
I tried change some export setup, but it didn't work. Thank you in advance for any ideas!
brylamichal97
To add more details to this problem. I tried to export it in Structural Plan, when I exported in 3D view the problem dissapeard and displays correctly. I don't know why the problem is in Structural Plan. Do you have any ideas?
EDIT:
I found a solution, the problem was the scope of the project. In my case it was too large, however, in order to generate the Model Text correctly it should be exported on a 3d view and then the visibility will be correct.
