Break Line Problems,otherside of breakline
skelkit17
skelkit17
Hi guys!
When using breakline, I don't want to see otherside of breakline. How can I fix it? Thank you
MichaelDol
I think you are missing the masking area.
Mikhail Dolgikh / Михаил Долгих
BIM-Manager & Teacher / БИМ-Менеджер - Учитель
Facebook
skelkit17
How can I fix it?
MichaelDol
look at the files attached above
Facebook
Mike.FORM
Add a masking region into the family. here is a snip of the one I use. There is a masking region drawn with invisible lines in addition to the actual lines for the break graphic. The masking region can also be turned on and off with visibility parameter.
