Hardware Acceleration disabled
I just bought an iMac :
iMac (Retina 5K, 27 pouces, fin 2015)
3,3 GHz Intel Core i5
8 Go 1867 MHz DDR3
AMD Radeon R9 M395 2048 Mo
And I'm running Revit 2015/or 2016 via parrallels desktop 11.
The message "Hardware acceleration disabled. Software emulation mode is in use" is stopping the process everytime.
Can somebody advise please ?
Many thanks 🙂
Marina
e_azzam
@Anonymous
hi,
this is caused by your graphic card not supported by revit,
chech here if ur graphic card certified or not
http://usa.autodesk.com/adsk/servlet/syscert?siteID=123112&id=18844534&results=1&stype=graphic&product_group=2&release=2015&os=8192&manuf=2&opt=1
Arch.Esam azzam
Revit Architecture ACI
BIM Manager
VRAY Licensed Trainer
Hi @e_azzam
Thanks for your answer.
My card is not certified. The card name is Parallels Display Adaptater WDDM.
So is there any other way to run Revit on my computer ?
Thanks for your help.
any resolution on this?
also, am i correct in assuming the disabling of the hardware acceleration is may be to blame for frequent graphic issues and crashing?
ennujozlagam
@Anonymous hello try to lower your display setting  to 1920 x 1080 and see if this helps. thanks
