Halftone background in sections
kbevingtonN6US5
kbevingtonN6US5
I am cutting a section through a house using a view template but want anything past the cut to show up halftone. Is there a way to do this? Can I get the same effect using the view template? TIA.
hmunsell
have you looked into Depth Cueing?
https://help.autodesk.com/view/RVT/2025/ENU/?guid=GUID-114C785D-280D-4B93-940F-E730FEDDB29E
Howard Munsell
kbevingtonN6US5
After looking into Depth Cueing, it seems to fade depending on the distance from the cut. I want to have everything past the cut line at halftone independent of distance. Is that possible?
