Gutter not showing in 3d view
sebas_alva_g
sebas_alva_g
Hi!
There is a gutter on this roof. It appears in the roof plan view but not in the 3d view. Is there a way to make it appear on the 3d view? Thanks!
Alfredo_Medina
By looking at your Project Browser, it seems that you have a project with phases. Perhaps in the 3d view the gutter is not visible because it was modeled in the New Construction phase while this view is set to show Existing only?
syman2000
Did you use out of the box Gutter profile or you create your own profile? Also check which if the gutter is placed in design options.
Is Gutter turned on in the 3D view?
sebas_alva_g
Hi! I remodeled the gutter and now it appears, thank you!
