Grouping wall type in schedule
MVE1112
Message 1 of 9
MVE1112
Hi everyone,
There  is probably a very easy solution that i am just not seeing..
I am trying make a schedule that shows just the total area of walls per wall type.
I attached an image in which you can see Revit showing the same wall types multiple times..
I need to create a schedule to easily see for the whole facade what the area is for insulation, brick outer wall and inner wall..
Replies (8)
Message 2 of 9
Under Sorting/Grouping did you uncheck Itemize every instance?
Message 3 of 9
MVE1112
Yes i have.
I included another picture of all the settings for this schedule.
Edit:
I added another picure of the formating settings for type and area.
Message 4 of 9
Tick Grand Totals and under formatting, Area to show Calculate totals.
Message 5 of 9
MVE1112
Thanks for the quick responses!
I did that but it didnt really change the schedule..
See attached:)
Message 6 of 9
Sort by type only.
Message 7 of 9
MVE1112
That solves part of the problem.
Now i see a total sum of the walls like i wanted.
But i need to sort it by Mark aswell
I gave all walls a mark based on the orientation(facing north south east west) and i need to calculate per facade, so per orientation what the area per wall type is..
Message 8 of 9
MVE1112
So for some reason,
After sorting by type only it did combine all similar types in one row but wouldnt allow me to filter the type by mark.
I added a filter by mark afterwards and now it works..
If someone wants to explain why this works like this please do.
I will accept both of you as solution.
Thanks for the help!
Message 9 of 9
Adding Sort by Type with Not itemize instances will separate different types to different rows: Type 1, Type 2, etc.... Adding Sort by Mark will further divide each Type to different rows: Type 1 - Mark 1, Type 1 - Mark 2, Ty[e 2 - Mark 1, Type 2 - Mark 2. etc...
