@jfjacques wrote:
What is meant by grip edit?
Select a grid, and then use the blue dot on the end to re-position it. Click and drag.
Do you mean just pull them back within the crop region?
No see above. Move them independent of the crop region
Thing is the crop regions are different on every sheet- should the crop region on one sheet affect the gridlines (2d) on another sheet?
No. But not every grid may be set to 2D on every view. That is what i suspect is the problem. you have some that are 3D (moving in every view) and others in 2D.
I have been pulling them within the crop region, they still seem to move.
Sounds like you are adjusting the 3D extents.
Also this doesn't address the issues that hiding and showing the view on the exterior of the crop region moves the gridlines.
That is turning the crop on and off. Yes this would change the position of the grid line end. If the crop was pulled in past the 3D extents of the grid, it will automatically "trim" it to the crop edge. When you turn off cropping the grid will return to it's 3D extents.
Moreover when I crop the gridlines and check to hide annotations in PP, some gridlines hide and others stay visible.
- Also wondering why this feature exists in the first place. Crop regions and gridlines often have to move independently of each other, especially on a tight sheet. Also gridlines already move easily as a unit. What's the point of this feature?
The feature is there to automatically "trim" gridlines when you crop a view, otherwise you would need to touch every grid every time. with automatic trimming, that may not necessarily be required every time.
I would again suggest looking over the topics in the section of the help on datum extents and visibility. http://help.autodesk.com/view/RVT/2020/ENU/?guid=GUID-4E36EDA0-2F4E-4619-B568-AC758E8D9770
Lots of good information there and would probably answer a lot of these questions.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
