grid line priority in 2d
Hi guys. Today i run into some issue.
i make the grid lines. but It's line is upper than model line when i see the floor plan.
i wanna like this one. how can i do it?? 😂😂😂
before
after
thanks.  may you be full of happiness😁😁
You could probably get there through a clever manipulation of these settings:
Create a Grid Line with a Center Gap | Revit Products 2016 | Autodesk Knowledge Network
Half toned lines always stay on top, which is very silly.  Keep the grid lines black so that they blend with instead of sit on top of other lines, until they fix this idiotic graphic priority.
