grid line points attachment to a surface
shershahbacha9
Message 1 of 16
shershahbacha9
Hey experienced people !!
i want to compare the differences between two earth surfaces and i came across something regarding gridlines but i am unclear about it.
its like creating gridline mesh on level 0 , then project the points of grid on two surfaces which are above gridline mesh.
Can someone help me regarding it and explain the method a little after creating a gridline mesh
Accepted solutions (3)
Replies (15)
Message 2 of 16
 "Compare the differences between two earth surfaces"??? Do you mean between two Revit Topsurfaces?
Message 3 of 16
shershahbacha9
yes exactly
Message 4 of 16
Do you mean this?
Message 5 of 16
shershahbacha9
i think no. i mean gridlines and their intersections
Message 6 of 16
What exactly are you wanting to compare between the 2 Toposurfaces?
Message 7 of 16
shershahbacha9
The difference in their heights at different points
Message 8 of 16
RDAOU
@shershahbacha9
Not sure where you read about the method you mentioned above and what they recommended therein...but Revit doesn't do what you are asking for. As a matter of fact, AutoCAD and Civil 3D does that better.
Best that Revit does is overlaying 2 x 3D topo-surfaces and calculate the cut and fill. To project a 3D topo surface on a plane you need to use Dynamo...something you can do in AutoCAD or civil 3D with 1 command
Isn't this the same as you previous discussion which you started one month ago? I think it is lol
Message 9 of 16
Why?
Message 10 of 16
shershahbacha9
Thanks but i have to do it in Revit and yes i am trying now in dynamo. Yes i did before a month but i couldnt understand what really to do and i was doing others tasks of my student project. Now my deadline is near and i have to do it anyway and thats why again posted but this time about this specific process
Message 11 of 16
RDAOU
Both are Toposurfaces in Revit format? or do you still have that google earth/sketchup thing
Message 12 of 16
shershahbacha9
both are toposurfaces in revit format and in same file
Message 13 of 16
RDAOU
Ok...I am not sure what you are supposed to present but I think the below might do it
  1. then lay a grid
  2. Place Sections along each grid line (X and Y)
  3. Place an entourage family consisting of a model line as a place holder at the grid intersections
  4. Open sections and place coordinates at the hosting point between the entourage family and each toposurface
  5. Place them on a sheet
Upload your file I will try to do a quick screencast showing you how the above will look like
Message 14 of 16
RDAOU
@shershahbacha9
This is what was meant by the above...not sure still if this is what your assignment is about
Message 15 of 16
RDAOU
@shershahbacha9
Here is the screencast (family + 1 site ...you can make the first invisible and repeat the same for the second site )
Message 16 of 16
shershahbacha9
Thank you so much
