GRID LINE DISAPPEAR WHEN I CHANGE ITS NUMBER
basma_salman
Message 1 of 8
basma_salman
I have a problem when I change the name of the grid line it disappear from the plan but it is showing in the elevations and sections
Replies (7)
Message 2 of 8
alberto-secondi
Could you share more details? Revit version or anything that may be relevant.
Could it be a filter in your view or view template?
To check that create a brand new floor plan on the same level and see if you still get the same error. The new view should reset all the VG stuff. 90% of quirky issues like that get solved when I create new views.
HTH!
Message 3 of 8
Do you have rule-based Filters acting on the View?
Message 4 of 8
You say: "when I open the ground floor plan there is grid G when I change it into C it disappears from plans but it shows in elevations and sections"
I am surprised Revit didn't throw an error on you. You can't change G to C because you already have a C, and that's what you are seeing in Elevation/Section. You are seeing the existing Grid C .
Open your "ELEVATION 03" and Reveal Hidden Elements. You'll immediately see the Grid  G displayed in the View just to to the left of your Grid C.
Message 5 of 8
basma_salman
yes I know that because GRID C is not appearing in my plans but it is only appearing in sections and elevations,
try to delete grid G and solve my problem to show grid C in plans
Message 6 of 8
basma_salman
No
Message 7 of 8
This Filter is acting on the Ground Floor View.  Remove the Filter from Ground Floor View and Grid C will be visible.
Message 8 of 8
basma_salman
thank you very much😁
