Grid line bubble naming in level 1 is automately changing another level 2 and level 3 why?
s.karuppuswamy
s.karuppuswamy
this is i am created
but
in the next level
 A,B,C is change automately to P,Q ,R,
why i dont know please explain
Don't copy paste grids from one level to another, that will create new numbers..  Delete the PQR... grids, open an uncropped elevation view and stretch the grids up then they will show properly on upper level(s).
s.karuppuswamy
thanks
i did that
you say don't copy the grid line to the next level, when i delete the it appears same name
okay
but in the next further more at final top roof level it was not displayed
need solution
what will i do kindly help
@s.karuppuswamy wrote:
thanks
i did that
okay
need solution
As said already, go the uncropped elevation and stretch the grids to pass the roof level.
s.karuppuswamy
thanks
i got it
how mean go to elevation view drag the ,open an uncropped elevation view and stretch the grids up then they will show properly on upper level(s).
thanks
i got it
Not sure if it is a question but I answer with this image.
