Grey Glass Problem Material Assignment
Side view of Glass is Grey, I want it to be transparent. I cannot understand how to make that happend. Did I assign the materials wrong? I guess not...?
What else could it be?
rudi.roux
Hi @Anonymous
Everything looks fine under your Material Graphics, just make sure that the "Glass" Material is the actual one used in the curtain wall or windows family. It might be that you need to change the material graphics settings for the one below. (Depicted in you image).
If you already checked that, then the other possibility is that there is a Cut Pattern Override assigned to your windows category in your project.
Go to your Visibility/Graphic Overrides (VV or VG) and go down to your Windows Category, is there possibly a Cut Pattern assigned as indicated below?
If there is, Clear the Overrides. Let me know if that was the problem.
I hope this helps! Smiley Happy
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
I am using glass as a wall. Could I make it non-grey?
See the pictures for my current settings.
artejon
Could you upload a file ?
Revit add-ins: CAD Purger (delete UNUSED and selected line patterns & line styles, find and delete CAD), Rooms To Spaces, Schedule Utilities (Calculated Values/Combined Parameters To Tags, reuse view filter rules in schedule filters), View Filter Manager at Revit Apps Store
rudi.roux
Did you have a look at your Cut Pattern Overrides? You could even set an
override as I indicated to ensure that the Glass/Window/Glazing displays in
the way/color of your choice.
Rudi Roux
LinkedIn
WeTransfer-link: https://we.tl/DhByfSfIRo
It is a file with glass in it. Do you see what I am doing wrong?
artejon
In type properties of a glass wall set Wrapping at Ends to 'Exterior' or "Interior'.
