Green Roof Pattern
Green Roof Pattern
noconnorG728Y
Message 1 of 13
Green Roof Pattern
noconnorG728Y
I am trying to work out a pattern for green roof in Fill Pattern. I created it by using PyRevit. But when I created the filled region or add pattern to surface of an element (Roof) . It is coming out blank. I tried to override the graphics view of the element but nothing is happening. See images attached. The pattern is about 100mm tall.
Any suggestion would be greatly appreciated
Replies (12)
Message 2 of 13
graeme.wallace
Could you maybe upload the .pat file so I can test it? might just be a scale issue?
Out of interest is it a drafting or model pattern?
Message 3 of 13
Is the roof surface actually visible in the view?
Message 4 of 13
noconnorG728Y
I thought about the scale issue but we scale it up from 20mm to 100mm
Message 5 of 13
Does it display in 3D? If it does but not in your plan then it could be a visibility issue?
Message 6 of 13
noconnorG728Y
Just the colour but not the pattern
Message 7 of 13
noconnorG728Y
Does not display on 3D and 2D
Message 8 of 13
Use a Plan Region to change View Range at Roof.
Message 9 of 13
set the pattern to either foreground or background, not both.
Message 10 of 13
Are the Roof Projection Lines turned on in the View? What color are they?  255-255-255?
Message 11 of 13
noconnorG728Y
Hello
I did more investigation. I created a new project and the pattern and filled region are grand so when I copied it to the existing project (not before I deleted the roof types and purge used)..............The 2nd image tell me that I am losing the pattern and it is making it gray......???
Also none of the pattern/filled region such as Diagonal Crosshatch are showing too. Does this mean that the model is corrupted?
Message 12 of 13
noconnorG728Y
Hello
Message 13 of 13
Transfer Project Standards to bring the fill patterns, materials, and roof types from the New project into your project.
