Greater than formula for paramter
Message 1 of 14
Is there a formula for a parameter if a pipe size is larger than a certain size it will add length to the current value to make the length longer?
Example,
Line size is 1.5" and I have a width of 2" and need to add 2" to width if line size becomes 2" or larger.
Replies (13)
Message 2 of 14
Sorry for double replies
Message 3 of 14
If ( 0<line size<2", line size+.5", line size+2")
Message 4 of 14
Alfredo_Medina
That formula is incorrect. It gives the error of "Improper use of boolean expressions".
Maybe this is what @Anonymous is trying to do for the Width parameter?
if(not(line size < 2"), line size + 2", line size)
Message 5 of 14
You are correct. Revised below:
if(line size < 0' 2", line size + 0' 0 1/2", line size + 0' 2")
Message 6 of 14
You can do IF(AND(0<Line Size,Line Size<2"), ResultIfTrue, ResultIfFalse) but that depends on what you are trying to accomplish.
If you want to round to every increment of 2" you would create a parameter "Actual Line Size"=ROUNDUP(Line Size/2")*2". Then 1 1/2"/2 = 0.75 which rounds up to 1. 1*2=2. 6-1/2"/2"=3.25, 3.25 rounds up to 4, 4*2"=8"
Message 7 of 14
Alfredo_Medina
@Anonymous , @ToanDN
Please notice that the request in the original message says "...need to add 2" to 'width' if 'line size' becomes 2" or larger."
Therefore,...
1) if the value of "line size" is less than 2", "width" should not be modified.
2) if the value of "line size" is 2, "width" should be increased by 2".
3) If the value of line size is greater than 2", "width" should be increased by 2", as well.
Message 8 of 14
@Alfredo_Medina
You could be right.  I will let OP clarify if he needs to.
From my point of view, this sort of rules is very common when creating penetrations for pipes, ductwork, or conduits.
For smaller pipes (less than 2" diameter, the holes diameters only need to be 1/2" larger the pipes'.  For larger pipes (2" or over), the holes' diameters need to be 2" larger than the pipes' to give enough room for adjustment, caulking, and whatnots.
They align with requirements you would find in the UL systems.
Message 9 of 14
Alfredo_Medina
My point is, that, regardless of the practical applications of the formula, the IF statement has to include the the value of 2" as a condition to do something, not just the values less than 2". In one of the formulas shown above the conditional statement says "if this parameter is less than 2", do this, otherwise do that". The other formula says "if this parameter is greater than zero and less than 2", do this, otherwise do that". None of these formulas is considering that the request was "if this value is 2" or greater", do this, do that", which is different.
Message 10 of 14
It does.
Width:  if(line size < 0' 2", line size + 0' 0 1/2", line size + 0' 2")
If line size < 2" then Width = line size + 1/2".  Else, Width = line size + 2".
What do you think Else is there for?  Of course, it is there to address the condition of line size = or > 2".
Message 11 of 14
RDAOU
Hmmmm...
if(not(line size < 2"), line size + 2", line size) @Alfredo_Medina
if(line size < 0' 2", line size, line size + 0' 2") @ToanDN
I believe both are correct statements to achieve the same end result...well They give the same output..., one says if it is not less (i.e.: only greater) do something and the second says if it is less do nothing!!!
However, The OP is variating the width by +2" to its original value and not to the line size i.e.: width cannot be equal to width + 2" (circular chain)
Example,
  • An additional parameter should be added to control width
  1. Parameter "Width" for the user to input value
  2. Parameter "Width_CTRL" which labels the dimension on the drawing (i.e.:controls width of the pipe placed in the model
  • use any of the above formula formats amended as follows
  1. Width_CTRL = if(not(line size < 2"), Width + 2", Width)
  2. Width_CTRL = if(line size < 2", Width, Width + 2")
=> user inputs both values or both values are given (Line size and Width)....formula compares and amends Width_CTRL in the model
or at least that's how I understand the request
Message 12 of 14
I have used this formula and it works great.
if(Parameter> #, Parameter, Parameter +#)
in use would say
if(Nom Dia > 1 1/2", Nom Dia, Length +2")
Message 13 of 14
Alfredo_Medina
To help with the discussion, this is a comparison of the 3 formulas presented above, with an initial as a suffix at the end of the parameter.
  • I added the "result if true" and "result if false".to the width_test_J parameter, since it was not specified.
  • There are 2 formulas that work correctly for all 3 conditions. One of them does not work when the value is less than 2".
  • I agree that in reality, to change the actual width of something, we would need another parameter.
Message 14 of 14
RDAOU
What's the conclusion? The outputs of the following conditional statements are not the same? Or what?
if(line size < 2", line size, line size + 2")
