- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm doing a simple addition and renovation to an existing house. In the existing house, I'm only replacing new windows & doors in the existing R.O.'s. I've only placed one instance of the windows & doors and have them as New Construction, and the walls are Existing. I did not want to place one instance of the windows and doors as Existing Demo'd and then a second instance of the same as New Construction.
In the attached screen shot, the left view is an elevation view is an elevation and the right view is a section view of the front of an existing house. I want the elevation views to look like the section views. The view template for each view uses the exact same phase filter. The only way I can make the graphics look as desired is to modify wall profile and cut a hole around each window & door. PIA work around.
Are the other graphic setting that I'm missing? Are there built-in graphics settings for elevation and section views that causes graphics of the same view to appear different?
